Time Before: 0.00230 seconds
Time After: 0.00300 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00312 seconds
Time After: 0.00351 seconds
Time Before: 0.00376 seconds
Time After: 0.00391 seconds
Time Before: 0.00477 seconds
Time After: 0.00751 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00399 seconds
Time After: 0.01271 seconds
Time Taken: 0.00872 seconds
Time Before: 0.01528 seconds
Time After: 0.01561 seconds
Time Before: 0.01808 seconds
Time After: 0.01928 seconds
Time Before: 0.01444 seconds
Time After: 0.01956 seconds
Time Taken: 0.00512 seconds
Time Before: 0.02715 seconds
Time After: 0.02729 seconds
Time Before: 0.03053 seconds
Time After: 0.03212 seconds
Time Taken: 0.00159 seconds
Time Before: 0.03491 seconds
Time After: 0.03502 seconds
Time Before: 0.03693 seconds
Time After: 0.03834 seconds
UPDATE session SET lastactivity = 1788913199, location = '/forums/private.php?do=newpm&explain=1&u=111381', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05983 seconds
Time After: 0.06031 seconds
