Time Before: 0.00140 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00237 seconds
Time Before: 0.00255 seconds
Time After: 0.00269 seconds
Time Before: 0.00361 seconds
Time After: 0.00612 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00277 seconds
Time After: 0.00995 seconds
Time Taken: 0.00718 seconds
Time Before: 0.01245 seconds
Time After: 0.01294 seconds
Time Before: 0.01605 seconds
Time After: 0.01760 seconds
Time Taken: 0.00155 seconds
Time Before: 0.01170 seconds
Time After: 0.01781 seconds
Time Taken: 0.00611 seconds
Time Before: 0.02289 seconds
Time After: 0.02311 seconds
Time Before: 0.02605 seconds
Time After: 0.02726 seconds
Time Before: 0.03056 seconds
Time After: 0.03069 seconds
Time Before: 0.03327 seconds
Time After: 0.03476 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=111406', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.05232 seconds
Time After: 0.05264 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
