Time Before: 0.00173 seconds
Time After: 0.00231 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00241 seconds
Time After: 0.00291 seconds
Time Before: 0.00315 seconds
Time After: 0.00326 seconds
Time Before: 0.00414 seconds
Time After: 0.00667 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00334 seconds
Time After: 0.01151 seconds
Time Taken: 0.00817 seconds
Time Before: 0.01374 seconds
Time After: 0.01416 seconds
Time Before: 0.01554 seconds
Time After: 0.01671 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01308 seconds
Time After: 0.01689 seconds
Time Taken: 0.00381 seconds
Time Before: 0.02215 seconds
Time After: 0.02232 seconds
Time Before: 0.02488 seconds
Time After: 0.02617 seconds
End call of global.php: 0.028872966766357
Time Before: 0.03055 seconds
Time After: 0.03076 seconds
Time Before: 0.03305 seconds
Time After: 0.03448 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=111460', badlocation = 1
Time Before: 0.04678 seconds
Time After: 0.04705 seconds
Page generated in 0.045892000198364 seconds with 9 queries, spending 0.0080816745758057 doing MySQL queries and 0.037810325622559 doing PHP things.
