Time Before: 0.00185 seconds
Time After: 0.00347 seconds
Time Taken: 0.00162 seconds
Time Before: 0.00354 seconds
Time After: 0.00402 seconds
Time Before: 0.00432 seconds
Time After: 0.00447 seconds
Time Before: 0.00512 seconds
Time After: 0.00773 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00452 seconds
Time After: 0.01120 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01325 seconds
Time After: 0.01366 seconds
Time Before: 0.01614 seconds
Time After: 0.01740 seconds
Time Before: 0.01255 seconds
Time After: 0.01765 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02487 seconds
Time After: 0.02501 seconds
Time Before: 0.02746 seconds
Time After: 0.02870 seconds
Time Before: 0.03227 seconds
Time After: 0.03240 seconds
Time Before: 0.03440 seconds
Time After: 0.03584 seconds
UPDATE session SET lastactivity = 1776565890, location = '/forums/private.php?do=newpm&explain=1&u=111463' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.04817 seconds
Time After: 0.04847 seconds
