Time Before: 0.01553 seconds
Time After: 0.02109 seconds
Time Taken: 0.00556 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02119 seconds
Time After: 0.02164 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02204 seconds
Time After: 0.02241 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02376 seconds
Time After: 0.02629 seconds
Time Taken: 0.00253 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02247 seconds
Time After: 0.03035 seconds
Time Taken: 0.00788 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03569 seconds
Time After: 0.03615 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03853 seconds
Time After: 0.03977 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.03501 seconds
Time After: 0.04000 seconds
Time Taken: 0.00499 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.07140 seconds
Time After: 0.07154 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.11223 seconds
Time After: 0.11425 seconds
Time Taken: 0.00202 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.11641716957092
Time Before: 0.13824 seconds
Time After: 0.13840 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.14306 seconds
Time After: 0.14452 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1773292058, location = '/forums/private.php?do=newpm&explain=1&u=111479', badlocation = 1
Time Before: 0.16874 seconds
Time After: 0.16906 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.16777014732361 seconds with 9 queries, spending 0.0091493129730225 doing MySQL queries and 0.15862083435059 doing PHP things.
