Time Before: 0.02814 seconds
Time After: 0.03563 seconds
Time Taken: 0.00750 seconds
Time Before: 0.03573 seconds
Time After: 0.03613 seconds
Time Before: 0.03635 seconds
Time After: 0.03645 seconds
Time Taken: 0.00010 seconds
Time Before: 0.03725 seconds
Time After: 0.03922 seconds
Time Taken: 0.00198 seconds
Time Before: 0.03650 seconds
Time After: 0.04369 seconds
Time Taken: 0.00719 seconds
Time Before: 0.05238 seconds
Time After: 0.05282 seconds
Time Before: 0.05583 seconds
Time After: 0.05706 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05162 seconds
Time After: 0.05724 seconds
Time Taken: 0.00562 seconds
Memory After: 2,261.820 KB
Time Before: 0.08914 seconds
Time After: 0.08933 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10789 seconds
Time After: 0.10912 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.12556 seconds
Time After: 0.12577 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.12850 seconds
Time After: 0.12992 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788899146, location = '/forums/private.php?do=newpm&explain=1&u=111483' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.15012 seconds
Time After: 0.15045 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
