Time Before: 0.02581 seconds
Time After: 0.04185 seconds
Time Taken: 0.01603 seconds
Time Before: 0.04197 seconds
Time After: 0.04240 seconds
Time Before: 0.04267 seconds
Time After: 0.04286 seconds
Time Before: 0.04362 seconds
Time After: 0.04643 seconds
Time Taken: 0.00281 seconds
Time Before: 0.04293 seconds
Time After: 0.05066 seconds
Time Taken: 0.00773 seconds
Time Before: 0.06095 seconds
Time After: 0.06121 seconds
Time Before: 0.06264 seconds
Time After: 0.06386 seconds
Time Before: 0.06008 seconds
Time After: 0.06408 seconds
Time Taken: 0.00400 seconds
Time Before: 0.11957 seconds
Time After: 0.11978 seconds
Time Before: 0.16988 seconds
Time After: 0.17114 seconds
Time Before: 0.18631 seconds
Time After: 0.18651 seconds
Time Before: 0.18975 seconds
Time After: 0.19119 seconds
UPDATE session SET lastactivity = 1776541320, location = '/forums/private.php?do=newpm&explain=1&u=111501', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.21204 seconds
Time After: 0.21234 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
