Time Before: 0.01697 seconds
Time After: 0.01980 seconds
Time Taken: 0.00283 seconds
Time Before: 0.01990 seconds
Time After: 0.02036 seconds
Time Before: 0.02068 seconds
Time After: 0.02082 seconds
Time Before: 0.02180 seconds
Time After: 0.02401 seconds
Time Taken: 0.00221 seconds
Time Before: 0.02090 seconds
Time After: 0.02831 seconds
Time Taken: 0.00741 seconds
Time Before: 0.03300 seconds
Time After: 0.03342 seconds
Time Before: 0.03585 seconds
Time After: 0.03712 seconds
Time Before: 0.03236 seconds
Time After: 0.03736 seconds
Time Taken: 0.00500 seconds
Time Before: 0.06565 seconds
Time After: 0.06583 seconds
Time Before: 0.07735 seconds
Time After: 0.07862 seconds
End call of global.php: 0.081206083297729
Time Before: 0.08600 seconds
Time After: 0.08622 seconds
Time Before: 0.08901 seconds
Time After: 0.09113 seconds
Time Taken: 0.00212 seconds
SET lastactivity = 1783233956, location = '/forums/private.php?do=newpm&explain=1&u=111520', badlocation = 1
Time Before: 0.10892 seconds
Time After: 0.10920 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.10777497291565 seconds with 9 queries, spending 0.0085866451263428 doing MySQL queries and 0.099188327789307 doing PHP things.
