Time Before: 0.00681 seconds
Time After: 0.01035 seconds
Time Taken: 0.00354 seconds
Time Before: 0.01045 seconds
Time After: 0.01090 seconds
Time Before: 0.01114 seconds
Time After: 0.01132 seconds
Time Before: 0.01210 seconds
Time After: 0.01477 seconds
Time Taken: 0.00267 seconds
Time Before: 0.01138 seconds
Time After: 0.01865 seconds
Time Taken: 0.00727 seconds
Time Before: 0.02441 seconds
Time After: 0.02482 seconds
Time Before: 0.02768 seconds
Time After: 0.02890 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02380 seconds
Time After: 0.02923 seconds
Time Taken: 0.00542 seconds
Memory After: 2,261.836 KB
Memory Used: 132.898 KB
Time Before: 0.04547 seconds
Time After: 0.04561 seconds
Memory Before: 2,815.383 KB
Memory After: 2,815.898 KB
Time Before: 0.05805 seconds
Time After: 0.05974 seconds
Time Taken: 0.00168 seconds
Memory Before: 2,903.578 KB
Memory After: 2,904.172 KB
End call of global.php: 0.062312126159668
Time Before: 0.06745 seconds
Time After: 0.06760 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.07017 seconds
Time After: 0.07165 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
SET lastactivity = 1788983262, location = '/forums/private.php?do=newpm&explain=1&u=111521', badlocation = 1
Time Before: 0.09213 seconds
Time After: 0.09240 seconds
Memory Before: 4,287.914 KB
Memory After: 4,288.125 KB
Page generated in 0.090966939926147 seconds with 9 queries, spending 0.0086641311645508 doing MySQL queries and 0.082302808761597 doing PHP things.
