Time Before: 0.01183 seconds
Time After: 0.01612 seconds
Time Taken: 0.00429 seconds
Time Before: 0.01620 seconds
Time After: 0.01674 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01698 seconds
Time After: 0.01710 seconds
Time Before: 0.01784 seconds
Time After: 0.02019 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01717 seconds
Time After: 0.02404 seconds
Time Taken: 0.00688 seconds
Time Before: 0.02990 seconds
Time After: 0.03032 seconds
Time Before: 0.03297 seconds
Time After: 0.03416 seconds
Time Before: 0.02928 seconds
Time After: 0.03437 seconds
Time Taken: 0.00509 seconds
Time Before: 0.06230 seconds
Time After: 0.06246 seconds
Time Before: 0.07681 seconds
Time After: 0.07837 seconds
Time Taken: 0.00156 seconds
Time Before: 0.08849 seconds
Time After: 0.08887 seconds
Time Before: 0.09143 seconds
Time After: 0.09288 seconds
UPDATE session SET lastactivity = 1777268814, location = '/forums/private.php?do=newpm&explain=1&u=111538' WHERE sessionhash = '435038dab37e0d85e0e0321e175b4499'
Time Before: 0.11031 seconds
Time After: 0.11080 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
