Time Before: 0.00152 seconds
Time After: 0.00204 seconds
Time Before: 0.00210 seconds
Time After: 0.00251 seconds
Time Before: 0.00268 seconds
Time After: 0.00278 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00344 seconds
Time After: 0.00563 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00282 seconds
Time After: 0.00908 seconds
Time Taken: 0.00625 seconds
Time Before: 0.01084 seconds
Time After: 0.01125 seconds
Time Before: 0.01258 seconds
Time After: 0.01375 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01021 seconds
Time After: 0.01404 seconds
Time Taken: 0.00383 seconds
Time Before: 0.02104 seconds
Time After: 0.02118 seconds
Time Before: 0.02320 seconds
Time After: 0.02448 seconds
Time Before: 0.02835 seconds
Time After: 0.02853 seconds
Time Before: 0.03079 seconds
Time After: 0.03221 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=111601', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04490 seconds
Time After: 0.04523 seconds
