Time Before: 0.00193 seconds
Time After: 0.00252 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00262 seconds
Time After: 0.00302 seconds
Time Before: 0.00327 seconds
Time After: 0.00341 seconds
Time Before: 0.00419 seconds
Time After: 0.00671 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00346 seconds
Time After: 0.01011 seconds
Time Taken: 0.00664 seconds
Time Before: 0.01192 seconds
Time After: 0.01237 seconds
Time Before: 0.01382 seconds
Time After: 0.01499 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01133 seconds
Time After: 0.01516 seconds
Time Taken: 0.00383 seconds
Time Before: 0.02021 seconds
Time After: 0.02071 seconds
Time Before: 0.02349 seconds
Time After: 0.02470 seconds
Time Before: 0.02805 seconds
Time After: 0.02822 seconds
Time Before: 0.03030 seconds
Time After: 0.03173 seconds
UPDATE session SET lastactivity = 1776711444, location = '/forums/private.php?do=newpm&explain=1&u=111620' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.04453 seconds
Time After: 0.04493 seconds
