Time Before: 0.00135 seconds
Time After: 0.00184 seconds
Time Before: 0.00191 seconds
Time After: 0.00231 seconds
Time Before: 0.00261 seconds
Time After: 0.00279 seconds
Time Before: 0.00371 seconds
Time After: 0.00663 seconds
Time Taken: 0.00292 seconds
Time Before: 0.00287 seconds
Time After: 0.01151 seconds
Time Taken: 0.00864 seconds
Time Before: 0.01355 seconds
Time After: 0.01395 seconds
Time Before: 0.01658 seconds
Time After: 0.01783 seconds
Time Before: 0.01277 seconds
Time After: 0.01808 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02433 seconds
Time After: 0.02454 seconds
Time Before: 0.02700 seconds
Time After: 0.02833 seconds
Time Taken: 0.00133 seconds
Time Before: 0.03237 seconds
Time After: 0.03256 seconds
Time Before: 0.03562 seconds
Time After: 0.03713 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=11164' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.05135 seconds
Time After: 0.05167 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
