Time Before: 0.01119 seconds
Time After: 0.01419 seconds
Time Taken: 0.00300 seconds
Time Before: 0.01429 seconds
Time After: 0.01475 seconds
Time Before: 0.01516 seconds
Time After: 0.01531 seconds
Time Before: 0.01601 seconds
Time After: 0.01874 seconds
Time Taken: 0.00273 seconds
Time Before: 0.01537 seconds
Time After: 0.02357 seconds
Time Taken: 0.00819 seconds
Time Before: 0.02875 seconds
Time After: 0.02898 seconds
Time Before: 0.03163 seconds
Time After: 0.03285 seconds
Time Before: 0.02797 seconds
Time After: 0.03313 seconds
Time Taken: 0.00517 seconds
Time Before: 0.05393 seconds
Time After: 0.05413 seconds
Time Before: 0.06723 seconds
Time After: 0.06857 seconds
Time Taken: 0.00134 seconds
Time Before: 0.07926 seconds
Time After: 0.07944 seconds
Time Before: 0.08206 seconds
Time After: 0.08352 seconds
UPDATE session SET lastactivity = 1776839138, location = '/forums/private.php?do=newpm&explain=1&u=111663', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.10447 seconds
Time After: 0.10505 seconds
Time Taken: 0.00058 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
