Time Before: 0.00129 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00238 seconds
Time Before: 0.00261 seconds
Time After: 0.00306 seconds
Time Before: 0.00382 seconds
Time After: 0.00682 seconds
Time Taken: 0.00300 seconds
Time Before: 0.00310 seconds
Time After: 0.01023 seconds
Time Taken: 0.00713 seconds
Time Before: 0.01207 seconds
Time After: 0.01226 seconds
Time Before: 0.01463 seconds
Time After: 0.01583 seconds
Time Before: 0.01152 seconds
Time After: 0.01600 seconds
Time Taken: 0.00449 seconds
Time Before: 0.02094 seconds
Time After: 0.02112 seconds
Time Before: 0.02340 seconds
Time After: 0.02467 seconds
Time Before: 0.02747 seconds
Time After: 0.02765 seconds
Time Before: 0.02961 seconds
Time After: 0.03103 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=111677', badlocation = 1 WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.04391 seconds
Time After: 0.04428 seconds
