Time Before: 0.01513 seconds
Time After: 0.01889 seconds
Time Taken: 0.00377 seconds
Time Before: 0.01899 seconds
Time After: 0.01938 seconds
Time Before: 0.01961 seconds
Time After: 0.01973 seconds
Time Before: 0.02055 seconds
Time After: 0.02283 seconds
Time Taken: 0.00227 seconds
Time Before: 0.01980 seconds
Time After: 0.02744 seconds
Time Taken: 0.00764 seconds
Time Before: 0.03494 seconds
Time After: 0.03535 seconds
Time Before: 0.03849 seconds
Time After: 0.03980 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03423 seconds
Time After: 0.04007 seconds
Time Taken: 0.00585 seconds
Time Before: 0.05645 seconds
Time After: 0.05676 seconds
Time Before: 0.06882 seconds
Time After: 0.07009 seconds
Time Before: 0.07748 seconds
Time After: 0.07764 seconds
Time Before: 0.08085 seconds
Time After: 0.08243 seconds
Time Taken: 0.00158 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=11169' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.10114 seconds
Time After: 0.10146 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
