Time Before: 0.01392 seconds
Time After: 0.02006 seconds
Time Taken: 0.00614 seconds
Time Before: 0.02013 seconds
Time After: 0.02050 seconds
Time Before: 0.02071 seconds
Time After: 0.02084 seconds
Time Before: 0.02162 seconds
Time After: 0.02391 seconds
Time Taken: 0.00230 seconds
Time Before: 0.02091 seconds
Time After: 0.02832 seconds
Time Taken: 0.00742 seconds
Time Before: 0.03743 seconds
Time After: 0.03780 seconds
Time Before: 0.04029 seconds
Time After: 0.04150 seconds
Time Before: 0.03676 seconds
Time After: 0.04174 seconds
Time Taken: 0.00498 seconds
Time Before: 0.06185 seconds
Time After: 0.06201 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"41.39,\";s:9:\"lastcheck\";i:1785319286;}', 1)Time Before: 0.07448 seconds
Time After: 0.07505 seconds
Time Taken: 0.00057 seconds
Memory Before: 2,817.297 KB
Memory After: 2,817.547 KB
Memory Used: 0.250 KB
Time Before: 0.08893 seconds
Time After: 0.09018 seconds
Memory Before: 2,904.602 KB
Memory After: 2,905.195 KB
Time Before: 0.09890 seconds
Time After: 0.09911 seconds
Memory Before: 3,541.359 KB
Memory After: 3,541.789 KB
Time Before: 0.10213 seconds
Time After: 0.10358 seconds
Memory Before: 3,823.094 KB
Memory After: 3,824.781 KB
UPDATE session SET lastactivity = 1785319286, location = '/forums/private.php?do=newpm&explain=1&u=111777', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12199 seconds
Time After: 0.12231 seconds
Memory Before: 4,297.086 KB
Memory After: 4,297.297 KB
