Time Before: 0.01314 seconds
Time After: 0.01523 seconds
Time Taken: 0.00209 seconds
Time Before: 0.01532 seconds
Time After: 0.01571 seconds
Time Before: 0.01598 seconds
Time After: 0.01612 seconds
Time Before: 0.01697 seconds
Time After: 0.02029 seconds
Time Taken: 0.00333 seconds
Time Before: 0.01618 seconds
Time After: 0.02580 seconds
Time Taken: 0.00962 seconds
Time Before: 0.03055 seconds
Time After: 0.03075 seconds
Time Before: 0.03369 seconds
Time After: 0.03501 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02991 seconds
Time After: 0.03522 seconds
Time Taken: 0.00531 seconds
Memory After: 2,261.820 KB
Time Before: 0.06012 seconds
Time After: 0.06034 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 2.71854 seconds
Time After: 2.72022 seconds
Time Taken: 0.00168 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 2.73171 seconds
Time After: 2.73211 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 2.73492 seconds
Time After: 2.73660 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788932410, location = '/forums/private.php?do=newpm&explain=1&u=111796' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 2.75867 seconds
Time After: 2.75910 seconds
Memory Before: 4,288.359 KB
Memory After: 4,288.586 KB
