Time Before: 0.01507 seconds
Time After: 0.01959 seconds
Time Taken: 0.00452 seconds
Time Before: 0.01969 seconds
Time After: 0.02010 seconds
Time Before: 0.02035 seconds
Time After: 0.02050 seconds
Time Before: 0.02128 seconds
Time After: 0.02386 seconds
Time Taken: 0.00258 seconds
Time Before: 0.02058 seconds
Time After: 0.02780 seconds
Time Taken: 0.00722 seconds
Time Before: 0.03651 seconds
Time After: 0.03700 seconds
Time Before: 0.03969 seconds
Time After: 0.04087 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03568 seconds
Time After: 0.04107 seconds
Time Taken: 0.00539 seconds
Time Before: 0.07421 seconds
Time After: 0.07435 seconds
Time Before: 0.08505 seconds
Time After: 0.08626 seconds
End call of global.php: 0.088284969329834
Time Before: 0.09511 seconds
Time After: 0.09532 seconds
Time Before: 0.09891 seconds
Time After: 0.10038 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=111869'
Time Before: 0.11894 seconds
Time After: 0.11937 seconds
Page generated in 0.11781787872314 seconds with 9 queries, spending 0.0082705020904541 doing MySQL queries and 0.10954737663269 doing PHP things.
