Time Before: 0.00163 seconds
Time After: 0.00212 seconds
Time Before: 0.00218 seconds
Time After: 0.00264 seconds
Time Before: 0.00292 seconds
Time After: 0.00307 seconds
Time Before: 0.00397 seconds
Time After: 0.00659 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00315 seconds
Time After: 0.00995 seconds
Time Taken: 0.00680 seconds
Time Before: 0.01163 seconds
Time After: 0.01197 seconds
Time Before: 0.01322 seconds
Time After: 0.01442 seconds
Time Before: 0.01107 seconds
Time After: 0.01471 seconds
Time Taken: 0.00364 seconds
Time Before: 0.02169 seconds
Time After: 0.02185 seconds
Time Before: 0.02396 seconds
Time After: 0.02523 seconds
Time Before: 0.02852 seconds
Time After: 0.02890 seconds
Time Before: 0.03088 seconds
Time After: 0.03229 seconds
UPDATE session SET lastactivity = 1789147955, location = '/forums/private.php?do=newpm&explain=1&u=111871', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04447 seconds
Time After: 0.04476 seconds
