Time Before: 0.02312 seconds
Time After: 0.02801 seconds
Time Taken: 0.00489 seconds
Time Before: 0.02810 seconds
Time After: 0.02863 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02894 seconds
Time After: 0.02910 seconds
Time Before: 0.02998 seconds
Time After: 0.03297 seconds
Time Taken: 0.00299 seconds
Time Before: 0.02918 seconds
Time After: 0.03764 seconds
Time Taken: 0.00847 seconds
Time Before: 0.04525 seconds
Time After: 0.04544 seconds
Time Before: 0.04790 seconds
Time After: 0.04909 seconds
Time Before: 0.04461 seconds
Time After: 0.04936 seconds
Time Taken: 0.00475 seconds
Time Before: 0.07956 seconds
Time After: 0.07973 seconds
Time Before: 0.09203 seconds
Time After: 0.09342 seconds
Time Taken: 0.00139 seconds
Time Before: 0.10202 seconds
Time After: 0.10216 seconds
Time Before: 0.10464 seconds
Time After: 0.10613 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=111923', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.12568 seconds
Time After: 0.12591 seconds
