Time Before: 0.00762 seconds
Time After: 0.01311 seconds
Time Taken: 0.00549 seconds
Time Before: 0.01324 seconds
Time After: 0.01374 seconds
Time Before: 0.01414 seconds
Time After: 0.01429 seconds
Time Before: 0.01515 seconds
Time After: 0.01779 seconds
Time Taken: 0.00264 seconds
Time Before: 0.01437 seconds
Time After: 0.02200 seconds
Time Taken: 0.00763 seconds
Time Before: 0.02795 seconds
Time After: 0.02832 seconds
Time Before: 0.03096 seconds
Time After: 0.03219 seconds
Time Before: 0.02725 seconds
Time After: 0.03238 seconds
Time Taken: 0.00513 seconds
Time Before: 0.04530 seconds
Time After: 0.04543 seconds
Time Before: 0.05921 seconds
Time After: 0.06049 seconds
Time Before: 0.06901 seconds
Time After: 0.06915 seconds
Time Before: 0.07195 seconds
Time After: 0.07386 seconds
Time Taken: 0.00191 seconds
UPDATE session SET lastactivity = 1776970903, location = '/forums/private.php?do=newpm&explain=1&u=111924', badlocation = 1 WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.09341 seconds
Time After: 0.09368 seconds
