Time Before: 0.00133 seconds
Time After: 0.00187 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00194 seconds
Time After: 0.00267 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00295 seconds
Time After: 0.00310 seconds
Time Before: 0.00399 seconds
Time After: 0.00656 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00317 seconds
Time After: 0.01078 seconds
Time Taken: 0.00761 seconds
Time Before: 0.01267 seconds
Time After: 0.01310 seconds
Time Before: 0.01540 seconds
Time After: 0.01661 seconds
Time Before: 0.01200 seconds
Time After: 0.01678 seconds
Time Taken: 0.00478 seconds
Time Before: 0.02193 seconds
Time After: 0.02224 seconds
Time Before: 0.02424 seconds
Time After: 0.02546 seconds
Time Before: 0.02836 seconds
Time After: 0.02860 seconds
Time Before: 0.03087 seconds
Time After: 0.03233 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=111929' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.04615 seconds
Time After: 0.04646 seconds
