Time Before: 0.01703 seconds
Time After: 0.02126 seconds
Time Taken: 0.00422 seconds
Time Before: 0.02135 seconds
Time After: 0.02184 seconds
Time Before: 0.02210 seconds
Time After: 0.02223 seconds
Time Before: 0.02308 seconds
Time After: 0.02563 seconds
Time Taken: 0.00255 seconds
Time Before: 0.02230 seconds
Time After: 0.02983 seconds
Time Taken: 0.00754 seconds
Time Before: 0.03709 seconds
Time After: 0.03750 seconds
Time Before: 0.04005 seconds
Time After: 0.04121 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03551 seconds
Time After: 0.04140 seconds
Time Taken: 0.00589 seconds
Time Before: 0.07632 seconds
Time After: 0.07649 seconds
Time Before: 0.36607 seconds
Time After: 0.36731 seconds
Time Before: 0.37470 seconds
Time After: 0.37490 seconds
Time Before: 0.37715 seconds
Time After: 0.37860 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=111988', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.40189 seconds
Time After: 0.40214 seconds
