Time Before: 0.00809 seconds
Time After: 0.01109 seconds
Time Taken: 0.00301 seconds
Time Before: 0.01116 seconds
Time After: 0.01152 seconds
Time Before: 0.01173 seconds
Time After: 0.01187 seconds
Time Before: 0.01262 seconds
Time After: 0.01475 seconds
Time Taken: 0.00212 seconds
Time Before: 0.01194 seconds
Time After: 0.01896 seconds
Time Taken: 0.00702 seconds
Time Before: 0.02330 seconds
Time After: 0.02367 seconds
Time Before: 0.02600 seconds
Time After: 0.02719 seconds
Time Before: 0.02271 seconds
Time After: 0.02739 seconds
Time Taken: 0.00468 seconds
Time Before: 0.04603 seconds
Time After: 0.04616 seconds
Time Before: 0.05386 seconds
Time After: 0.05518 seconds
Time Taken: 0.00131 seconds
Time Before: 0.06235 seconds
Time After: 0.06255 seconds
Time Before: 0.06545 seconds
Time After: 0.06690 seconds
UPDATE session SET lastactivity = 1776533177, location = '/forums/private.php?do=newpm&explain=1&u=111997' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.08284 seconds
Time After: 0.08362 seconds
Time Taken: 0.00078 seconds
