Time Before: 0.00873 seconds
Time After: 0.01336 seconds
Time Taken: 0.00463 seconds
Time Before: 0.01343 seconds
Time After: 0.01392 seconds
Time Before: 0.01415 seconds
Time After: 0.01434 seconds
Time Before: 0.01514 seconds
Time After: 0.01746 seconds
Time Taken: 0.00232 seconds
Time Before: 0.01441 seconds
Time After: 0.02153 seconds
Time Taken: 0.00712 seconds
Time Before: 0.02584 seconds
Time After: 0.02633 seconds
Time Before: 0.02883 seconds
Time After: 0.03036 seconds
Time Taken: 0.00152 seconds
Time Before: 0.02519 seconds
Time After: 0.03057 seconds
Time Taken: 0.00538 seconds
Time Before: 0.05072 seconds
Time After: 0.05087 seconds
Time Before: 0.06450 seconds
Time After: 0.06582 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.068846940994263
Time Before: 0.07370 seconds
Time After: 0.07386 seconds
Time Before: 0.07622 seconds
Time After: 0.07767 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=112003'
Time Before: 0.09296 seconds
Time After: 0.09331 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.091996908187866 seconds with 9 queries, spending 0.0084340572357178 doing MySQL queries and 0.083562850952148 doing PHP things.
