Time Before: 0.00145 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00258 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00282 seconds
Time After: 0.00298 seconds
Time Before: 0.00365 seconds
Time After: 0.00640 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00303 seconds
Time After: 0.01039 seconds
Time Taken: 0.00736 seconds
Time Before: 0.01259 seconds
Time After: 0.01299 seconds
Time Before: 0.01593 seconds
Time After: 0.01842 seconds
Time Taken: 0.00249 seconds
Time Before: 0.01171 seconds
Time After: 0.01866 seconds
Time Taken: 0.00695 seconds
Time Before: 0.02703 seconds
Time After: 0.02719 seconds
Time Before: 0.03029 seconds
Time After: 0.03160 seconds
End call of global.php: 0.034106969833374
Time Before: 0.03568 seconds
Time After: 0.03582 seconds
Time Before: 0.03852 seconds
Time After: 0.03996 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=112017', badlocation = 1
Time Before: 0.05365 seconds
Time After: 0.05391 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.052402019500732 seconds with 9 queries, spending 0.0096893310546875 doing MySQL queries and 0.042712688446045 doing PHP things.
