Time Before: 0.00141 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00235 seconds
Time Before: 0.00255 seconds
Time After: 0.00270 seconds
Time Before: 0.00337 seconds
Time After: 0.00618 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00276 seconds
Time After: 0.01102 seconds
Time Taken: 0.00826 seconds
Time Before: 0.01292 seconds
Time After: 0.01333 seconds
Time Before: 0.01482 seconds
Time After: 0.01615 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01222 seconds
Time After: 0.01633 seconds
Time Taken: 0.00411 seconds
Time Before: 0.02138 seconds
Time After: 0.02152 seconds
Time Before: 0.02332 seconds
Time After: 0.02455 seconds
End call of global.php: 0.026242971420288
Time Before: 0.02748 seconds
Time After: 0.02763 seconds
Time Before: 0.02982 seconds
Time After: 0.03130 seconds
SET lastactivity = 1788891646, location = '/forums/private.php?do=newpm&explain=1&u=112074'
Time Before: 0.04417 seconds
Time After: 0.04479 seconds
Time Taken: 0.00062 seconds
Page generated in 0.043262958526611 seconds with 9 queries, spending 0.0087401866912842 doing MySQL queries and 0.034522771835327 doing PHP things.
