Time Before: 0.00148 seconds
Time After: 0.00201 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00208 seconds
Time After: 0.00263 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00285 seconds
Time After: 0.00300 seconds
Time Before: 0.00367 seconds
Time After: 0.00825 seconds
Time Taken: 0.00458 seconds
Time Before: 0.00305 seconds
Time After: 0.01163 seconds
Time Taken: 0.00858 seconds
Time Before: 0.01343 seconds
Time After: 0.01391 seconds
Time Before: 0.01642 seconds
Time After: 0.01760 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01284 seconds
Time After: 0.01776 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02262 seconds
Time After: 0.02316 seconds
Time Before: 0.02516 seconds
Time After: 0.02640 seconds
Time Before: 0.02982 seconds
Time After: 0.03000 seconds
Time Before: 0.03205 seconds
Time After: 0.03350 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=112099' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04843 seconds
Time After: 0.04878 seconds
