Time Before: 0.00193 seconds
Time After: 0.00238 seconds
Time Before: 0.00245 seconds
Time After: 0.00349 seconds
Time Taken: 0.00104 seconds
Time Before: 0.00389 seconds
Time After: 0.00408 seconds
Time Before: 0.00544 seconds
Time After: 0.00917 seconds
Time Taken: 0.00373 seconds
Time Before: 0.00416 seconds
Time After: 0.01371 seconds
Time Taken: 0.00955 seconds
Time Before: 0.01544 seconds
Time After: 0.01590 seconds
Time Before: 0.01877 seconds
Time After: 0.02064 seconds
Time Taken: 0.00187 seconds
Time Before: 0.01486 seconds
Time After: 0.02084 seconds
Time Taken: 0.00597 seconds
Time Before: 0.02794 seconds
Time After: 0.02814 seconds
Time Before: 0.03023 seconds
Time After: 0.03156 seconds
Time Taken: 0.00133 seconds
Time Before: 0.03467 seconds
Time After: 0.03486 seconds
Time Before: 0.03686 seconds
Time After: 0.03927 seconds
Time Taken: 0.00241 seconds
UPDATE session SET lastactivity = 1789140353, location = '/forums/private.php?do=newpm&explain=1&u=112107' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.05229 seconds
Time After: 0.05260 seconds
