Time Before: 0.00382 seconds
Time After: 0.00494 seconds
Time Taken: 0.00112 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00505 seconds
Time After: 0.00547 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00579 seconds
Time After: 0.00592 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00678 seconds
Time After: 0.00944 seconds
Time Taken: 0.00266 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00598 seconds
Time After: 0.01426 seconds
Time Taken: 0.00828 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01857 seconds
Time After: 0.01899 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.02159 seconds
Time After: 0.02283 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01681 seconds
Time After: 0.02306 seconds
Time Taken: 0.00625 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.03050 seconds
Time After: 0.03063 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.03615 seconds
Time After: 0.03763 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
Time Before: 0.04258 seconds
Time After: 0.04273 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.04574 seconds
Time After: 0.04739 seconds
Time Taken: 0.00166 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=112115' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.06743 seconds
Time After: 0.06780 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
