Time Before: 0.02420 seconds
Time After: 0.03470 seconds
Time Taken: 0.01050 seconds
Time Before: 0.03478 seconds
Time After: 0.03519 seconds
Time Before: 0.03543 seconds
Time After: 0.03557 seconds
Time Before: 0.03642 seconds
Time After: 0.03898 seconds
Time Taken: 0.00256 seconds
Time Before: 0.03562 seconds
Time After: 0.04305 seconds
Time Taken: 0.00743 seconds
Time Before: 0.05446 seconds
Time After: 0.05488 seconds
Time Before: 0.05796 seconds
Time After: 0.05918 seconds
Time Before: 0.05366 seconds
Time After: 0.05940 seconds
Time Taken: 0.00573 seconds
Time Before: 0.09008 seconds
Time After: 0.09022 seconds
Time Before: 0.11916 seconds
Time After: 0.12039 seconds
End call of global.php: 0.12280797958374
Time Before: 0.12706 seconds
Time After: 0.12724 seconds
Time Before: 0.13002 seconds
Time After: 0.13150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=112123', badlocation = 1
WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.15327 seconds
Time After: 0.15366 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.15219688415527 seconds with 9 queries, spending 0.0081760883331299 doing MySQL queries and 0.14402079582214 doing PHP things.
