Time Before: 0.00147 seconds
Time After: 0.00206 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00214 seconds
Time After: 0.00257 seconds
Time Before: 0.00285 seconds
Time After: 0.00304 seconds
Time Before: 0.00388 seconds
Time After: 0.00665 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00309 seconds
Time After: 0.01172 seconds
Time Taken: 0.00863 seconds
Time Before: 0.01409 seconds
Time After: 0.01450 seconds
Time Before: 0.01715 seconds
Time After: 0.01834 seconds
Time Before: 0.01344 seconds
Time After: 0.01858 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02508 seconds
Time After: 0.02523 seconds
Time Before: 0.02753 seconds
Time After: 0.02875 seconds
End call of global.php: 0.030976057052612
Time Before: 0.03267 seconds
Time After: 0.03283 seconds
Time Before: 0.03490 seconds
Time After: 0.03654 seconds
Time Taken: 0.00164 seconds
SET lastactivity = 1785423879, location = '/forums/private.php?do=newpm&explain=1&u=112155'
Time Before: 0.05079 seconds
Time After: 0.05121 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.049829959869385 seconds with 9 queries, spending 0.0086002349853516 doing MySQL queries and 0.041229724884033 doing PHP things.
