Time Before: 0.00202 seconds
Time After: 0.00252 seconds
Time Before: 0.00259 seconds
Time After: 0.00309 seconds
Time Before: 0.00331 seconds
Time After: 0.00343 seconds
Time Before: 0.00416 seconds
Time After: 0.00621 seconds
Time Taken: 0.00204 seconds
Time Before: 0.00348 seconds
Time After: 0.00965 seconds
Time Taken: 0.00616 seconds
Time Before: 0.01155 seconds
Time After: 0.01188 seconds
Time Before: 0.01473 seconds
Time After: 0.01589 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01092 seconds
Time After: 0.01605 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02105 seconds
Time After: 0.02118 seconds
Time Before: 0.02332 seconds
Time After: 0.02453 seconds
End call of global.php: 0.026169061660767
Time Before: 0.02768 seconds
Time After: 0.02780 seconds
Time Before: 0.02983 seconds
Time After: 0.03123 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1789109147, location = '/forums/private.php?do=newpm&explain=1&u=112183', badlocation = 1
Time Before: 0.04350 seconds
Time After: 0.04382 seconds
Page generated in 0.042615175247192 seconds with 9 queries, spending 0.0073390007019043 doing MySQL queries and 0.035276174545288 doing PHP things.
