Time Before: 0.00139 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00240 seconds
Time Before: 0.00264 seconds
Time After: 0.00275 seconds
Time Before: 0.00348 seconds
Time After: 0.00565 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00280 seconds
Time After: 0.01013 seconds
Time Taken: 0.00733 seconds
Time Before: 0.01207 seconds
Time After: 0.01249 seconds
Time Before: 0.01399 seconds
Time After: 0.01519 seconds
Time Before: 0.01145 seconds
Time After: 0.01537 seconds
Time Taken: 0.00392 seconds
Time Before: 0.02097 seconds
Time After: 0.02110 seconds
Time Before: 0.02315 seconds
Time After: 0.02440 seconds
End call of global.php: 0.026793956756592
Time Before: 0.02853 seconds
Time After: 0.02868 seconds
Time Before: 0.03079 seconds
Time After: 0.03235 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1785301755, location = '/forums/private.php?do=newpm&explain=1&u=112208'
Time Before: 0.04572 seconds
Time After: 0.04602 seconds
Page generated in 0.044790983200073 seconds with 9 queries, spending 0.0077073574066162 doing MySQL queries and 0.037083625793457 doing PHP things.
