Time Before: 0.00138 seconds
Time After: 0.00184 seconds
Time Before: 0.00191 seconds
Time After: 0.00233 seconds
Time Before: 0.00257 seconds
Time After: 0.00270 seconds
Time Before: 0.00337 seconds
Time After: 0.00618 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00274 seconds
Time After: 0.00959 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01146 seconds
Time After: 0.01182 seconds
Time Before: 0.01412 seconds
Time After: 0.01534 seconds
Time Before: 0.01084 seconds
Time After: 0.01553 seconds
Time Taken: 0.00469 seconds
Time Before: 0.02074 seconds
Time After: 0.02089 seconds
Time Before: 0.02266 seconds
Time After: 0.02391 seconds
End call of global.php: 0.025582075119019
Time Before: 0.02681 seconds
Time After: 0.02696 seconds
Time Before: 0.02899 seconds
Time After: 0.03044 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=112213'
Time Before: 0.04731 seconds
Time After: 0.04762 seconds
Page generated in 0.046319961547852 seconds with 9 queries, spending 0.0082566738128662 doing MySQL queries and 0.038063287734985 doing PHP things.
