Time Before: 0.00192 seconds
Time After: 0.00256 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00266 seconds
Time After: 0.00313 seconds
Time Before: 0.00337 seconds
Time After: 0.00358 seconds
Time Before: 0.00422 seconds
Time After: 0.00675 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00363 seconds
Time After: 0.01109 seconds
Time Taken: 0.00745 seconds
Time Before: 0.01299 seconds
Time After: 0.01336 seconds
Time Before: 0.01595 seconds
Time After: 0.01714 seconds
Time Before: 0.01242 seconds
Time After: 0.01732 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02234 seconds
Time After: 0.02249 seconds
Time Before: 0.02432 seconds
Time After: 0.02553 seconds
End call of global.php: 0.027148008346558
Time Before: 0.02841 seconds
Time After: 0.02857 seconds
Time Before: 0.03136 seconds
Time After: 0.03281 seconds
SET lastactivity = 1789140162, location = '/forums/private.php?do=newpm&explain=1&u=112250', badlocation = 1
Time Before: 0.05016 seconds
Time After: 0.05068 seconds
Page generated in 0.04915714263916 seconds with 9 queries, spending 0.0082542896270752 doing MySQL queries and 0.040902853012085 doing PHP things.
