Time Before: 0.01900 seconds
Time After: 0.02551 seconds
Time Taken: 0.00651 seconds
Time Before: 0.02563 seconds
Time After: 0.02618 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02641 seconds
Time After: 0.02654 seconds
Time Before: 0.02747 seconds
Time After: 0.02991 seconds
Time Taken: 0.00245 seconds
Time Before: 0.02660 seconds
Time After: 0.03391 seconds
Time Taken: 0.00732 seconds
Time Before: 0.04091 seconds
Time After: 0.04111 seconds
Time Before: 0.04364 seconds
Time After: 0.04489 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04020 seconds
Time After: 0.04509 seconds
Time Taken: 0.00489 seconds
Memory After: 2,261.703 KB
Time Before: 0.07955 seconds
Time After: 0.07968 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.09606 seconds
Time After: 0.09727 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.099318027496338
Time Before: 0.10655 seconds
Time After: 0.10669 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10881 seconds
Time After: 0.11025 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=112311', badlocation = 1
Time Before: 0.12562 seconds
Time After: 0.12590 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.12458515167236 seconds with 9 queries, spending 0.0077700614929199 doing MySQL queries and 0.11681509017944 doing PHP things.
