Time Before: 0.01657 seconds
Time After: 0.02097 seconds
Time Taken: 0.00441 seconds
Time Before: 0.02110 seconds
Time After: 0.02151 seconds
Time Before: 0.02179 seconds
Time After: 0.02193 seconds
Time Before: 0.02272 seconds
Time After: 0.02492 seconds
Time Taken: 0.00219 seconds
Time Before: 0.02200 seconds
Time After: 0.02907 seconds
Time Taken: 0.00707 seconds
Time Before: 0.03583 seconds
Time After: 0.03628 seconds
Time Before: 0.03894 seconds
Time After: 0.04014 seconds
Time Before: 0.03506 seconds
Time After: 0.04039 seconds
Time Taken: 0.00533 seconds
Time Before: 0.07107 seconds
Time After: 0.07119 seconds
Time Before: 0.08439 seconds
Time After: 0.08563 seconds
Time Before: 0.09280 seconds
Time After: 0.09293 seconds
Time Before: 0.09541 seconds
Time After: 0.09688 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=112329', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.11371 seconds
Time After: 0.11430 seconds
Time Taken: 0.00060 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
