Time Before: 0.02458 seconds
Time After: 0.03512 seconds
Time Taken: 0.01054 seconds
Time Before: 0.03522 seconds
Time After: 0.03568 seconds
Time Before: 0.03589 seconds
Time After: 0.03602 seconds
Time Before: 0.03675 seconds
Time After: 0.03927 seconds
Time Taken: 0.00252 seconds
Time Before: 0.03607 seconds
Time After: 0.04360 seconds
Time Taken: 0.00753 seconds
Time Before: 0.05411 seconds
Time After: 0.05455 seconds
Time Before: 0.05599 seconds
Time After: 0.05716 seconds
Time Taken: 0.00117 seconds
Time Before: 0.05333 seconds
Time After: 0.05738 seconds
Time Taken: 0.00405 seconds
Time Before: 0.10579 seconds
Time After: 0.10592 seconds
Time Before: 0.13486 seconds
Time After: 0.13608 seconds
Time Before: 0.14619 seconds
Time After: 0.14639 seconds
Time Before: 0.14877 seconds
Time After: 0.15028 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1784735683, location = '/forums/private.php?do=newpm&explain=1&u=112333' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.16799 seconds
Time After: 0.17123 seconds
Time Taken: 0.00324 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
