Time Before: 0.00258 seconds
Time After: 0.00309 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00317 seconds
Time After: 0.00354 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00372 seconds
Time After: 0.00382 seconds
Time Taken: 0.00010 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00450 seconds
Time After: 0.00779 seconds
Time Taken: 0.00328 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00388 seconds
Time After: 0.01213 seconds
Time Taken: 0.00825 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01414 seconds
Time After: 0.01457 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01734 seconds
Time After: 0.01854 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01338 seconds
Time After: 0.01871 seconds
Time Taken: 0.00533 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02492 seconds
Time After: 0.02511 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.03197 seconds
Time After: 0.03320 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.035636901855469
Time Before: 0.04199 seconds
Time After: 0.04219 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.04445 seconds
Time After: 0.04589 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1772819453, location = '/forums/private.php?do=newpm&explain=1&u=112350', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.06285 seconds
Time After: 0.06314 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.061919927597046 seconds with 9 queries, spending 0.0087428092956543 doing MySQL queries and 0.053177118301392 doing PHP things.
