Time Before: 0.00140 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00225 seconds
Time Before: 0.00246 seconds
Time After: 0.00258 seconds
Time Before: 0.00322 seconds
Time After: 0.00557 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00262 seconds
Time After: 0.00895 seconds
Time Taken: 0.00633 seconds
Time Before: 0.01090 seconds
Time After: 0.01124 seconds
Time Before: 0.01313 seconds
Time After: 0.01434 seconds
Time Before: 0.01034 seconds
Time After: 0.01454 seconds
Time Taken: 0.00419 seconds
Memory After: 2,885.109 KB
Memory Used: 132.781 KB
Time Before: 0.02118 seconds
Time After: 0.02136 seconds
Memory Before: 3,438.211 KB
Memory After: 3,438.727 KB
Time Before: 0.02330 seconds
Time After: 0.02463 seconds
Time Taken: 0.00133 seconds
Memory Before: 3,525.906 KB
Memory After: 3,526.500 KB
End call of global.php: 0.026448011398315
Time Before: 0.02743 seconds
Time After: 0.02754 seconds
Memory Before: 4,163.813 KB
Memory After: 4,164.242 KB
Time Before: 0.03000 seconds
Time After: 0.03285 seconds
Time Taken: 0.00285 seconds
Memory Before: 4,445.375 KB
Memory After: 4,447.063 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=112359'
Time Before: 0.04565 seconds
Time After: 0.04600 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.044695138931274 seconds with 9 queries, spending 0.0092012882232666 doing MySQL queries and 0.035493850708008 doing PHP things.
