Time Before: 0.00377 seconds
Time After: 0.00654 seconds
Time Taken: 0.00277 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00664 seconds
Time After: 0.00813 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00848 seconds
Time After: 0.00865 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00952 seconds
Time After: 0.01165 seconds
Time Taken: 0.00212 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00873 seconds
Time After: 0.01624 seconds
Time Taken: 0.00751 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.02030 seconds
Time After: 0.02077 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.02337 seconds
Time After: 0.02460 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01957 seconds
Time After: 0.02486 seconds
Time Taken: 0.00529 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.03372 seconds
Time After: 0.03397 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.04107 seconds
Time After: 0.04357 seconds
Time Taken: 0.00250 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
End call of global.php: 0.045877933502197
Time Before: 0.04986 seconds
Time After: 0.05047 seconds
Time Taken: 0.00061 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.05334 seconds
Time After: 0.05483 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=112383'
Time Before: 0.07305 seconds
Time After: 0.08054 seconds
Time Taken: 0.00749 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
Page generated in 0.072064876556396 seconds with 9 queries, spending 0.017833471298218 doing MySQL queries and 0.054231405258179 doing PHP things.
