Time Before: 0.00198 seconds
Time After: 0.00265 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00273 seconds
Time After: 0.00316 seconds
Time Before: 0.00335 seconds
Time After: 0.00348 seconds
Time Before: 0.00427 seconds
Time After: 0.00661 seconds
Time Taken: 0.00234 seconds
Time Before: 0.00356 seconds
Time After: 0.01232 seconds
Time Taken: 0.00876 seconds
Time Before: 0.01449 seconds
Time After: 0.01467 seconds
Time Before: 0.01717 seconds
Time After: 0.01844 seconds
Time Before: 0.01391 seconds
Time After: 0.01874 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02621 seconds
Time After: 0.02635 seconds
Time Before: 0.02863 seconds
Time After: 0.03041 seconds
Time Taken: 0.00178 seconds
Time Before: 0.03395 seconds
Time After: 0.03413 seconds
Time Before: 0.03715 seconds
Time After: 0.03865 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=112386', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.05367 seconds
Time After: 0.05393 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
