Time Before: 0.00163 seconds
Time After: 0.00216 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00224 seconds
Time After: 0.00268 seconds
Time Before: 0.00293 seconds
Time After: 0.00307 seconds
Time Before: 0.00384 seconds
Time After: 0.00622 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00311 seconds
Time After: 0.01079 seconds
Time Taken: 0.00767 seconds
Time Before: 0.01264 seconds
Time After: 0.01292 seconds
Time Before: 0.01534 seconds
Time After: 0.01661 seconds
Time Before: 0.01198 seconds
Time After: 0.01685 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02351 seconds
Time After: 0.02367 seconds
Time Before: 0.02587 seconds
Time After: 0.02725 seconds
Time Taken: 0.00139 seconds
End call of global.php: 0.029371023178101
Time Before: 0.03144 seconds
Time After: 0.03166 seconds
Time Before: 0.03466 seconds
Time After: 0.03631 seconds
Time Taken: 0.00165 seconds
SET lastactivity = 1784768552, location = '/forums/private.php?do=newpm&explain=1&u=112394'
Time Before: 0.05093 seconds
Time After: 0.05136 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.049973964691162 seconds with 9 queries, spending 0.0083560943603516 doing MySQL queries and 0.041617870330811 doing PHP things.
