Time Before: 0.02503 seconds
Time After: 0.03187 seconds
Time Taken: 0.00684 seconds
Time Before: 0.03197 seconds
Time After: 0.03247 seconds
Time Before: 0.03272 seconds
Time After: 0.03285 seconds
Time Before: 0.03361 seconds
Time After: 0.03621 seconds
Time Taken: 0.00260 seconds
Time Before: 0.03291 seconds
Time After: 0.04031 seconds
Time Taken: 0.00739 seconds
Time Before: 0.05255 seconds
Time After: 0.05300 seconds
Time Before: 0.05567 seconds
Time After: 0.05690 seconds
Time Before: 0.05178 seconds
Time After: 0.05710 seconds
Time Taken: 0.00532 seconds
Time Before: 0.09497 seconds
Time After: 0.09517 seconds
Time Before: 0.11575 seconds
Time After: 0.11704 seconds
End call of global.php: 0.11931800842285
Time Before: 0.12533 seconds
Time After: 0.12546 seconds
Time Before: 0.12746 seconds
Time After: 0.12886 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1780672371, location = '/forums/private.php?do=newpm&explain=1&u=112434'
Time Before: 0.14599 seconds
Time After: 0.14630 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.14502286911011 seconds with 9 queries, spending 0.0082464218139648 doing MySQL queries and 0.13677644729614 doing PHP things.
