Time Before: 0.03675 seconds
Time After: 0.04280 seconds
Time Taken: 0.00605 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.04288 seconds
Time After: 0.04338 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.04369 seconds
Time After: 0.04386 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.04472 seconds
Time After: 0.04781 seconds
Time Taken: 0.00309 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.04394 seconds
Time After: 0.05224 seconds
Time Taken: 0.00830 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.05888 seconds
Time After: 0.05930 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.06074 seconds
Time After: 0.06203 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.05793 seconds
Time After: 0.06225 seconds
Time Taken: 0.00431 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.13193 seconds
Time After: 0.13241 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.21685 seconds
Time After: 0.21821 seconds
Time Taken: 0.00136 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.2203209400177
Time Before: 0.25957 seconds
Time After: 0.25973 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.26876 seconds
Time After: 0.27023 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1769368808, location = '/forums/private.php?do=newpm&explain=1&u=112450', badlocation = 1
WHERE sessionhash = 'e60efe98bb3a97c417ccaae1b39ae601'
Time Before: 0.30571 seconds
Time After: 0.30604 seconds
Memory Before: 5,999.000 KB
Memory After: 5,999.211 KB
Page generated in 0.30453991889954 seconds with 9 queries, spending 0.0092723369598389 doing MySQL queries and 0.2952675819397 doing PHP things.
