Time Before: 0.00193 seconds
Time After: 0.00263 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00269 seconds
Time After: 0.00309 seconds
Time Before: 0.00335 seconds
Time After: 0.00352 seconds
Time Before: 0.00417 seconds
Time After: 0.00773 seconds
Time Taken: 0.00356 seconds
Time Before: 0.00357 seconds
Time After: 0.01264 seconds
Time Taken: 0.00906 seconds
Time Before: 0.01475 seconds
Time After: 0.01511 seconds
Time Before: 0.01747 seconds
Time After: 0.01868 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01416 seconds
Time After: 0.01886 seconds
Time Taken: 0.00470 seconds
Memory After: 2,261.820 KB
Time Before: 0.02555 seconds
Time After: 0.02575 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02756 seconds
Time After: 0.02877 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03184 seconds
Time After: 0.03196 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03397 seconds
Time After: 0.03536 seconds
Time Taken: 0.00139 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789056093, location = '/forums/private.php?do=newpm&explain=1&u=112522', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05094 seconds
Time After: 0.05123 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
