Time Before: 0.00846 seconds
Time After: 0.01334 seconds
Time Taken: 0.00488 seconds
Time Before: 0.01343 seconds
Time After: 0.01379 seconds
Time Before: 0.01401 seconds
Time After: 0.01415 seconds
Time Before: 0.01488 seconds
Time After: 0.01728 seconds
Time Taken: 0.00240 seconds
Time Before: 0.01420 seconds
Time After: 0.02196 seconds
Time Taken: 0.00775 seconds
Time Before: 0.02784 seconds
Time After: 0.02865 seconds
Time Taken: 0.00080 seconds
Time Before: 0.03188 seconds
Time After: 0.03308 seconds
Time Before: 0.02714 seconds
Time After: 0.03326 seconds
Time Taken: 0.00612 seconds
Time Before: 0.04701 seconds
Time After: 0.04714 seconds
Time Before: 0.05333 seconds
Time After: 0.05462 seconds
Time Before: 0.06117 seconds
Time After: 0.06131 seconds
Time Before: 0.06352 seconds
Time After: 0.06498 seconds
UPDATE session SET lastactivity = 1785380775, location = '/forums/private.php?do=newpm&explain=1&u=112570', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.08522 seconds
Time After: 0.08558 seconds
