Time Before: 0.02521 seconds
Time After: 0.03550 seconds
Time Taken: 0.01029 seconds
Time Before: 0.03558 seconds
Time After: 0.03604 seconds
Time Before: 0.03625 seconds
Time After: 0.03636 seconds
Time Before: 0.03708 seconds
Time After: 0.03946 seconds
Time Taken: 0.00238 seconds
Time Before: 0.03642 seconds
Time After: 0.04350 seconds
Time Taken: 0.00708 seconds
Time Before: 0.05588 seconds
Time After: 0.05634 seconds
Time Before: 0.05896 seconds
Time After: 0.06021 seconds
Time Before: 0.05520 seconds
Time After: 0.06182 seconds
Time Taken: 0.00662 seconds
Time Before: 0.08588 seconds
Time After: 0.08601 seconds
Time Before: 0.11180 seconds
Time After: 0.11303 seconds
Time Before: 0.12499 seconds
Time After: 0.12514 seconds
Time Before: 0.12760 seconds
Time After: 0.12905 seconds
UPDATE session SET lastactivity = 1783622355, location = '/forums/private.php?do=newpm&explain=1&u=112588', badlocation = 1 WHERE sessionhash = 'b1e9f976e3e130f3a0e1c3e688e54b68'
Time Before: 0.15003 seconds
Time After: 0.15035 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
